Hi, my ssl connection no longer work after I upgrade from 8.0 to 8.1, I got those errors:
12-Apr-2019 19:29:23.203 SEVERE [https-openssl-nio-8443-exec-8] org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun
java.lang.UnsatisfiedLinkError: org.apache.tomcat.jni.SSL.renegotiatePending(J)I
at org.apache.tomcat.jni.SSL.renegotiatePending(Native Method)
at org.apache.tomcat.util.net.openssl.OpenSSLEngine.getHandshakeStatus(OpenSSLEngine.java:1021)
at org.apache.tomcat.util.net.openssl.OpenSSLEngine.wrap(OpenSSLEngine.java:457)
at javax.net.ssl.SSLEngine.wrap(SSLEngine.java:469)
at org.apache.tomcat.util.net.SecureNioChannel.handshakeWrap(SecureNioChannel.java:440)
at org.apache.tomcat.util.net.SecureNioChannel.handshake(SecureNioChannel.java:211)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1475)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
I have double check all my config for my ssl certificat but I still have same error.
there my connector:
<Connector
SSLEnabled="true"
acceptCount="100"
clientAuth="false"
connectionTimeout="20000"
disableUploadTimeout="true"
enableLookups="false"
keyAlias="jira"
keystoreFile="/opt/atlassian/jira.jks"
keystorePass="...."
keystoreType="JKS"
maxHttpHeaderSize="8192"
maxSpareThreads="75"
maxThreads="150"
minSpareThreads="25"
port="8443"
protocol="org.apache.coyote.http11.Http11NioProtocol"
scheme="https"
secure="true"
sslProtocol="TLS"
useBodyEncodingForURI="true"/>
and some logs from catalina.out:
12-Apr-2019 19:34:57.108 WARNING [main] org.apache.catalina.startup.SetAllPropertiesRule.begin [SetAllPropertiesRule]{Server/Service/Connector} Setting property 'maxSpareThreads' to '75' did not find a matching property.
12-Apr-2019 19:34:57.111 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.5.35
12-Apr-2019 19:34:57.112 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Nov 3 2018 17:39:20 UTC
12-Apr-2019 19:34:57.112 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.5.35.0
12-Apr-2019 19:34:57.112 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Linux
12-Apr-2019 19:34:57.112 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 3.10.0-957.10.1.el7.x86_64
12-Apr-2019 19:34:57.112 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
12-Apr-2019 19:34:57.112 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: /opt/atlassian/jira/jre
12-Apr-2019 19:34:57.112 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_181-b13
12-Apr-2019 19:34:57.112 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
12-Apr-2019 19:34:57.112 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: /opt/atlassian/jira
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: /opt/atlassian/jira
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=/opt/atlassian/jira/conf/logging.properties
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms484m
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx2048m
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:InitialCodeCacheSize=32m
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:ReservedCodeCacheSize=512m
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.awt.headless=true
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.standalone=JIRA
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true
12-Apr-2019 19:34:57.113 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dmail.mime.decodeparameters=true
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:-OmitStackTraceInFastThrow
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.locale.providers=COMPAT
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Datlassian.plugins.startup.options=
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djdk.tls.ephemeralDHKeySize=2048
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xloggc:/opt/atlassian/jira/logs/atlassian-jira-gc-%t.log
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseGCLogFileRotation
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:NumberOfGCLogFiles=5
12-Apr-2019 19:34:57.114 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:GCLogFileSize=20M
12-Apr-2019 19:34:57.115 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCDetails
12-Apr-2019 19:34:57.115 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCDateStamps
12-Apr-2019 19:34:57.115 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCTimeStamps
12-Apr-2019 19:34:57.115 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+PrintGCCause
12-Apr-2019 19:34:57.116 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dignore.endorsed.dirs=
12-Apr-2019 19:34:57.116 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=/opt/atlassian/jira
12-Apr-2019 19:34:57.116 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=/opt/atlassian/jira
12-Apr-2019 19:34:57.116 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=/opt/atlassian/jira/temp
12-Apr-2019 19:34:57.116 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent An older version [1.2.17] of the APR based Apache Tomcat Native library is installed, while Tomcat recommends a minimum version of [1.2.18]
12-Apr-2019 19:34:57.116 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent Loaded APR based Apache Tomcat Native library [1.2.17] using APR version [1.4.8].
12-Apr-2019 19:34:57.116 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true].
12-Apr-2019 19:34:57.116 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent APR/OpenSSL configuration: useAprConnector [false], useOpenSSL [true]
12-Apr-2019 19:34:57.119 INFO [main] org.apache.catalina.core.AprLifecycleListener.initializeSSL OpenSSL successfully initialized [OpenSSL 1.0.2k-fips 26 Jan 2017]
12-Apr-2019 19:34:57.263 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
12-Apr-2019 19:34:57.269 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["https-openssl-nio-8443"]
12-Apr-2019 19:34:57.462 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
12-Apr-2019 19:34:57.465 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 717 ms
12-Apr-2019 19:34:57.476 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service [Catalina]
12-Apr-2019 19:34:57.476 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.5.35
My certificate is still valid and was working fine just before I upgrade, someone have any idea?
Edit:
It seem 8.1 use tomcat version 8.5.35 and 8.0 was using 8.5.32, if I copy the lib/tomcat-* from 8.5.32 over the new version it's working, but I'm not sure what I'll broke by doing that.
I could solve it by upgrading the tomcat native library to 1.2.21.
Same problem here after we upgraded from 7.13.1 to 8.2.3. I seems to be related to the tomcat-native library (libtcnative-1.so). If we remove it, jira SSL works. Unfortunately we need it for other apps, sot that's not a solution. Looks like a bug in several tomcat versions, see also https://bugzilla.redhat.com/show_bug.cgi?id=1690651
cu,
Frank
Hi!
Could you change protocol="HTTP/1.1" instead of protocol="org.apache.coyote.http11.Http11NioProtocol", please?
