Good morning,
I would like to create an automation in JIRA Structure in order to insert directly all the Initiative that will be created into a specific project.
I created the empty structure, select Automation --> insert, but using this JQL "project = xxx and issuetype = Initiative", the system replies with the error attached to this ticket.
Can you help me solving this problem?
Amedeo
Hello @Amedeo
The mentioned error might indicate possible performance issues; in any case, it requires an investigation and a closer look at your setup. Please reach out to us directly through our support portal and we'll get back with you shortly.
Best regards,
Stepan Kholodov
Tempo
