I created really simple automation - when Epic issue type is created I want to create Task issue and link it to created Epic.
Problem is when I using 'Epic link' field, there is no option like "Current Issue", "Parent Issue", "Epic Issue", "Trigger Issue". I can see only "Copy from issue", "Copy from parent", "Copy from Epic", "Copy from trigger issue.
So basically, I'm not able to link Task issue to created Epic. Does anyone know why I can see only "Copy from..." options?
Hello @Dawid Ankowski
When asking for help with an Automation Rule, we need you to provide all the steps of the rule as options in later steps can be impacted by the earlier steps. Please show us all the rule steps.
You'll want to do is use a smart value {{issue}} which will link it to the trigger issue (your epic)
