Problems after restoring Jira Data Base
Roberto Lodigiani April 3, 2020
Hi
We had recently some problems with Jira (version 6.0.4) after a Database corruption
We have restored a Backup of the DataBase done couple days before the event
After restoring obviously we lost some issues created during the two days , but all the rest seems working
Only problem raised is that Greenhopper part ,in particular Agile boards , doesn't work , also some part of Epics issues are nor displayed the cause seems to be the same (see the log extracted ) and seems to be related to "ranking"
Also displaying other issues the error is logged but without any impact on the issues itsef
Does anyone have a suggestion on how to solve the problem?
Thank you
Roberto
rest.v2.issue.IssueBeanBuilder] Cannot get value from RestAwareField customfield_10002, exception: 'Sanity check for setting nextId of issue 110091 and custom field 10002 from null to 110100 failed. No entry for issue 110091 found'
[greenhopper.manager.rank.RankDaoImpl] Cannot manually remove erroneous transaction as it is unknown whether parts of the transaction have already been applied
[greenhopper.manager.rank.RankDaoImpl] Transaction sanity checked: yes
[greenhopper.manager.rank.RankDaoImpl] INSERT transaction (logId=124023, cfId=10002): before [issue insertion parameters check, 110091 -> null, no row for 110100] after [, 110091 -> 110100, 110100 -> null]
[greenhopper.manager.rank.RankDaoImpl] Outstanding rank operation transaction discovered. Trying to recover.
Daniel Ebers
April 10, 2020
Hi Roberto,
at least for the error message you mentioned very last I found a knowledge base article which refers to it.
While I am not confident that this will solve all errors definitely it might be part of the trouble you are currently experiencing.
Daniel
Roberto Lodigiani April 14, 2020
Thanks Daniel
the problem has been solved
Kind regards
Roberto
