I am converting my old custom JQL script to the new scriptrunner format. I made changes to the script according to documentation and have placed the script in the folder "E:\atlassian_home\Application Data\JIRA\scripts\com\onresolve\jira\groovy\jql".
I ran the scan utility and was able to find and address compilation errors. Once I got through those errors I ran scan again and got an error in the log, plus all of the bundled JQL disappeared. I was able to get the bundled JQL back by removing my script and then disabling/reeabling the plugin. I am at a loss as to where to go now. I will attach the relevant log entries in an attachment. FYI, I also tried to add a basic empty JQL script and had the same problem. I did remove my own JQL script before I tried the empty script.
Here is the beginning of the stack trace:
2018-02-26 13:48:53,056 http-nio-8080-exec-23 ERROR nancy.belser 828x57971x2 hyekzv 172.17.176.150,172.17.85.251 /rest/scriptrunner-jira/latest/jqlfunctions/list [c.a.p.r.c.error.jersey.ThrowableExceptionMapper] Uncaught exception thrown by REST service: com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
com.atlassian.util.concurrent.LazyReference$InitializationException: com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:149)
at com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:112)
at com.atlassian.util.concurrent.ResettableLazyReference.get(ResettableLazyReference.java:92)
at com.atlassian.util.concurrent.Supplier$get.call(Unknown Source)
at com.onresolve.scriptrunner.runner.JqlFunctionsManagerImpl.getScriptedFunctions(JqlFunctionsManagerImpl.groovy:167)
at com.onresolve.scriptrunner.runner.rest.jira.JqlFunctionsEndpoint.listJqlFunctions(JqlFunctionsEndpoint.groovy:136)
at com.onresolve.scriptrunner.runner.rest.jira.JqlFunctionsEndpoint.getScriptFunctionList(JqlFunctionsEndpoint.groovy:95)
... 3 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
... 19 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.doFilter(RestDelegatingServletFilter.java:154)
... 1 filtered
at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.doFilter(RestDelegatingServletFilter.java:68)
... 41 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 53 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 16 filtered
Could you provide your script?
