Problems with Labels in Jira
Chethana Hashani
I am working in a software company which uses jira as their PM tool. I need to filter tickets in a project which don't contain the label "Fixed_verified". So, I used the below query.
project = Piyasa AND labels != fix_verified
But in the list of tickets that i am getting from the above query, there are some missing tickets and those tickets don't contain the label "fixed_verified". This affects my master board and because of that currently I am unable to start the sprint as well. Please help me on this :)
2 accepted
Bryan Trummer - ReleaseTEAM
May 29, 2018
You also mention that it doesn't contain the label "Fixed_verified" but in your JQL its "fix_verified" and not "Fixed_verified".
Chethana Hashani
Hi Bryan,
Thanks for the support and I could fix the problem. I had to update me query as
project = Piyasa AND labels != fix_verified OR labels is EMPTY
Thanks a lot fr your support
May 30, 2018
Glad you were able to solve the issue.
Jack Brickey
are you sure the label is the same? verify case.
Chethana Hashani
Hi Jack,
Jack Brickey
yep that is absolutely needed if all issues aren't labeled. that one gets me from time to time. :-)
