  • Community
  • Q&A
  • Jira
  • Questions
  • Project with many issues types and workflows - need to allow/disallow transition based on one field
Bernd
I have a project with many Issues Types and Workflows (with sometimes many transitions). There is one field (-> called "blocked") which is present in all Issues Types.
If this value is set to "yes" no transition is allowed but there should be a warning/info  dialog that tells the user that the issue is currently blocked.
If blocked = yes the transition is allowed.
Questions:
- how I can I manage to do that without going through all WFs / transitions?
- how can I show a dialog/info to the user when he tries to transition the Issue?
Thanks in advance,
Bernd
Mohamed Benziane
Hello @Bernd
I think you will need a plugin like Scriptrunner to do what you want and write a Script Condition.
Regards
Bernd
@Mohamed Benziane: I have script runner .. so... how do I do it? ;-)
Mohamed Benziane
You will need to do this for all transistion, go to you workflow and add a condition based on a jql query (Allows the transition if this query matches a JQL query):
blocked!=yes
You can be more exhaustive in your query
Regards
Nic Brough -Adaptavist-
September 24, 2018
No, you are going to have to amend all the workflows you want to do this in.
You could do it with a condition, but that would hide the transition entirely so the user would have no feedback.  I'd say you probably want a validator, which can check what is in the field and return an error back to the user when validation fails.  It won't pop up a box, but will at least put something on-screen as a reason.
