Rapid7 Connection with Jira through Insight Connect
Afonso Alves April 3, 2025
Anybody here was able to connect Jira with rapid7 correctly?
Details
Requirements URL for Jira Software, Jira Server, or Jira ServiceDesk Jira user email address and API key when using Jira Cloud (Only JIRA cloud is supported with InsightConnect cloud connections.)
Jira username and password credentials when using on-prem Jira server
Supported Product Versions
Jira Server 6.0 Jira (Cloud)
Jira ServiceDesk (Cloud)
Marc - Devoteam
April 3, 2025
Hi @Afonso Alves
Welcome to the community.
This documentation should help to set this up: https://docs.rapid7.com/insightappsec/jira-integration/
On-prem instances pof Jira can't be used!
Thanks @Marc - Devoteam
I will go through this documentation and let you know if that works.
Like Marc - Devoteam likes this
