2 Jira instances on Same host ?
ashok2781 September 10, 2013
Is it prossibel to setup 2 jira Instances on Same host ?.
using different installation path, data folder path, DB. ??
Please Advise.
It's possible to run multiple JIRA instances on one machine as long as the instance completes the following requirements:
  • Not sharing the same listening or shutdown port of any other instance or service.
  • Not sharing the same database with another instance.
  • When using services within windows, using 2 different windows service definitions.
  • Not sharing the same JIRA home folder.
  • Not deploying multiple instances using a Single Tomcat Application Container.
  • Having separate licenses for each of the instances.
By default, JIRA runs on port 8080 (and hence is available at (http://<yourserver>:8080, eg. http://localhost:8080).
If you want to run another JIRA instance but already has a service claiming port 8080, there will be a conflict, and JIRA will fail to start. You may see errors like this:
Bhushan Patil November 2, 2017
Can you please help in understanding this?
Appreciate your response :)
Like SMPL Admin likes this
M Amine
It means not using the same Tomcat to deploy more than one Jira Instance: https://confluence.atlassian.com/jira/running-multiple-instances-of-jira-on-one-machine-222200571.html
Like # people like this
Abdoulaye Kindy Diallo
September 10, 2013
RambanamP
September 10, 2013
Christian Czaia [Decadis AG]
September 10, 2013
Definitely check the docs posted by the others... but answering your question: Yes, it is possible :-)
September 10, 2013
Funny thing, have you tried entering the same question in Google? Leads me to the documentation posted here :-)
