2 seperate burn down charts for same sprint
LAXMI ABHINAV REDDY ARAE January 28, 2022
 I have a Jira scrum board with 20 stories and I've created 2 different labels and assigned 10 stories in the sprint with one label and other 10 stories with another label. Is it possible to create 2 separate story/sprint burn down, health chart, sprint report gadgets  in dashboard?
If it isn't possible with labels, what is the best approach to achieve 2 separate burn down charts for same sprint?
Thank you!
Mark Segall
Hi @LAXMI ABHINAV REDDY ARAE
It is not possible to get multiple burn downs from the same sprint. However, there are a couple potential paths you could take:
Separate Projects
You could create a second project and give that the same sprint name and use a consolidated board to view all activity across projects.
Enable Parallel Sprints
You could split your work into parallel sprints.  See the article below for more information:
https://support.atlassian.com/jira-software-cloud/docs/use-parallel-sprints/
