404 and 500 error after base_url updated
Qi LUO May 13, 2015
I've just installed a new JIRA server, the server was first installed at a VM whose ip was xxx.
After that, I changed the VM ip to yyy
When I first browse JIRA by url yyy, login as root, it prompted me that base url needed to be updated to yyy, I approved. Now I'm keeping get 404 and 500 while browsing, some pages were ok, some were not
How to solve the problem? Thanks
sandhya May 14, 2015
I think
Context path under <jira-install>/conf/server.xml is not correct.
u can check and update Host name and while login to JIRA
u can give UrL: localhost:8080. it's by default...
if this port  is used by some other applications u need to change the port and try to login with new port.
 OR
u can try for this also:
Editing JIRA's General Configuration
To access and edit options on the 'General Configuration' page:
  1. Log in as a user with the JIRA Administrators global permission.
  2. Choose  > System. Select General Configuration to open the Administration page.  tick Keyboard shortcutg + g + start typing general configuration
  3. Edit Configuration button to edit   there is  a Base URL:The base URL of this JIRA installation
    u can check it once
Qi LUO May 14, 2015
solved, just followed the link https://answers.atlassian.com/questions/271604/oops-youve-found-a-dead-link don't know why, thanks anyway
