A problem about usage of Jira Versions
强 张 April 18, 2024
When the Versions field is in use, the drop-down box search must be entered from the first letter in order to search successfully, should not be entered any characters contained in the version can be searched
Bo Zhao
April 21, 2024
Hi @强 张
Fuzzy search might have been a default behaviour before but it seems Atlassian has changed it.
To do a fuzzy search, simply add ~ to the end of a single term, e.g. in your case, you can search for 0~
强 张 April 22, 2024
It do not work when search for 0~
Bilal Younas
April 19, 2024
It sounds like the Versions search functionality in Jira is limited, requiring you to start your search from the first letter of the version name.
Fabio Racobaldo _Catworkx_
Hi @强 张 and welcome,
version fields in JIRA shows unreleased list of versions first and you can filter that list typing release name. What is your desiderata?
Fabio
强 张 April 19, 2024
Such as my versions contain V1.0.1,V1.0.2 and  V1.1.1,  when I type '0', it can show V1.0.1 and V1.0.2. But now it show nothing.
Simply put, it's a fuzzy search.
SERVER
