×ASAP! HELP! Captcha 500 Error! Jira 7.3
com.atlassian.util.concurrent.LazyReference$InitializationException: java.lang.NoClassDefFoundError: Could not initialize class com.atlassian.jira.servlet.JiraImageCaptchaServiceImpl
I would like to see more of the logs to better determine what's going on. You should see a stack trace in the logs with a line that says Caused by and reason similar to this:
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
Please post as much of the stack trace and the caused by statements.
Branden
