I would like to create an email notification once a new issue is created with some specific email body namely with Linked Issue URLs and "Fix version(s)"
Below is the code. bold parts don't work. So, how can I do that?
A new {{issue.issueType.name}} - {{issue.url}} was created by {{creator.displayName}}
The summary '{{issue.fields.summary}}' and description '{{issue.fields.description}}' with the priority {{issue.priority.name}}
Linked Issues are;
'{{issue.fields.Links}}'
Attached Releases are;
'{{issue.fields.Fix Version(s)}}'
Regards
Hi Sabri - Welcome to the Atlassian Community!
Did you answer your own question then?
I've overlooked the URL - https://support.atlassian.com/cloud-automation/docs/jira-smart-values-issues/
