Activity stream does not load
Blommetje
I got my dashboard, but the activity stream just showing the loading bar.
I cannot modify anything in the admin settings.
Any ideas where to look for the solution? ()
Thomas Schlegel
Hi Maarten,
look here: https://jira.atlassian.com/browse/JRA-21901
or better here: https://jira.atlassian.com/browse/JRA-26008
it's a known bug
Best regards
Thomas
Thomas Schlegel
btw, Opera is not supported by Jira. So it's not a real bug...
Blommetje
Activity stream turned out to work fine, just not in Opera....
Blommetje
Michael S
January 31, 2012
Are you able to use other gadgets on your dashboard? If not, I'd check your Base URL.
It could also be an issue with your index, are you able to search for issues?
Blommetje
Yes, search works. I also see the 'Assigned to me-issues'. But the Projects, Issues in Progress and Road Map are just empty.
Michael S
January 31, 2012
Check your Base URL and make sure that it matches the URL you're using to access Confluence. It sounds like your gadgets aren't working.
Blommetje
yes, that is the issue. Well, i hadn't installed Confluence at all. Just bought it and installed it, but setup failed.
Now when i browse to the base url I'm directly send to http://localhost:8090/bootstrap/selectsetupstep.action with a system error.
Further from home I am.
Michael S
February 1, 2012
Without seeing your logging info, it could be that you have multiple installations. Do a search for 'confluence.cfg.xml' - if you find two then that's a good indicator.
If it's an evaluation you can start again by stopping Confluence and removing the home directory. When you start it back up again it'll be treated as a new install.
If you're still getting the error attach the stacktrace here. We may need to investigate a bit closer through http://support.atlassian.com.
Blommetje
There was only one .cfg.xml file , so i assume only one install.
It is an evaluation copy, so i can stop it. But with stopping do you mean killing the service, of de-install the software?
i don't know what a stacktrace is..
Below the log from the confluence.cfg.xml (partial due to message length)
<property name="confluence.webapp.context.path"></property>
<property name="hibernate.c3p0.acquire_increment">1</property>
<property name="hibernate.c3p0.idle_test_period">100</property>
<property name="hibernate.c3p0.max_size">30</property>
<property name="hibernate.c3p0.max_statements">0</property>
<property name="hibernate.c3p0.min_size">0</property>
<property name="hibernate.c3p0.timeout">30</property>
<property name="hibernate.connection.driver_class">org.hsqldb.jdbcDriver</property>
<property name="hibernate.connection.isolation">2</property>
<property name="hibernate.connection.password"></property>
<property name="hibernate.connection.url">jdbc:hsqldb:C:\Atlassian\ConfluenceData/database/confluencedb;hsqldb.tx=MVCC</property>
<property name="hibernate.connection.username">sa</property>
<property name="hibernate.dialect">com.atlassian.hibernate.dialect.HSQL2Dialect</property>
<property name="hibernate.setup">true</property>
<property name="lucene.index.dir">${confluenceHome}\index</property>
<property name="webwork.multipart.saveDir">${confluenceHome}\temp</property>
