×Does this product require a license? The plugin shows free but we cannot enable in Production: error This add-on failed to enable. It may require a license. Please refer to the logs for more information. Why cant we install based on the info below?
Logs
Exception in thread "Spring executor 19" org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'scriptManager' defined in URL [bundle://121.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is java.lang.VirtualMachineError: out of space in CodeCache for adapters
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:254)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:728)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355)
at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.VirtualMachineError: out of space in CodeCache for adapters
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callConstructor(AbstractCallSite.java:190)
at com.onresolve.jira.groovy.ScriptManagerImpl.<clinit>(ScriptManagerImpl.groovy:50)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:100)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:87)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:248)
... 21 more
Exception in thread "Spring executor 21" org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'scriptManager' defined in URL [bundle://122.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is java.lang.VirtualMachineError: out of space in CodeCache for adapters
... 21 more
Exception in thread "Spring executor 23" org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'scriptManager' defined in URL [bundle://123.0:0/META-INF/spring/atlassian-plugins-components.xml]: Instantiation of bean failed; nested exception is java.lang.VirtualMachineError: out of space in CodeCache for adapters
... 21 more
Duplicated to https://jamieechlin.atlassian.net/browse/GRV-808
Either add more memory or: -XX:ReservedCodeCacheSize=64m
Hi, the plugin was free. You need a license since version 4.0 .
Did you see "out of space in CodeCache"?
Probably you have to spend more memory to the virtual machine.
Take a look in the administration area. In System - Systeminformation you should see the memory consumption.
