Add a client to a single project and view only
Deleted user February 20, 2020
I need to add a client to a single project. He only needs to view issues on his project. What is the easiet way to do this? I have seen other posts on this forum but they are very old.
2 accepted
Adam Rypel _MoroSystems_
Deleted user February 21, 2020
Awesome thank you, I followed these steps and it worked!
Pete Singleton
February 20, 2020
It depends how your projects are set up with regard to Permission Schemes, i.e. do they all use the same one or does each project have a separate one?
To allow him to see issues in a project, you need to add him to the Browse Issues permission on the project's Permission Scheme.  But just check first that the Permission Scheme isn't shared with other projects.  If it is, then create a copy of it first, edit that one, and assign the copy to the single project.
Thank you, that was in the steps I tried below and it worked!
