×Hi there,
I would like to add a mandatory field to 1 project only. I had issues in the past that broke all the other PROJECTS because ticket was requiring this field
Field is a custom field with a checklist. I would like to add to our DEVELOPEMT project, make it required and assigned to the current Screen scheme for DEVELOPMENT
Hi Joao,
the steps would include:
1.) add a new customfield with a name you wish (ideally also add a context)
2.) add the newly created customfield to all desired screens of the screen scheme which is assigned to DEVELOPMENT projects
3.) create a new field configuration scheme and assign it to DEVELOPMENT project
4.) create a new field configuration for you new custom field (marking it as required)
The problem in the past will clearly have been to make the changes to existing field configuration instead of making a new one.
Hint: instead of creating a new custom field for the checklist you also can use a existing one in case you already have one.
Daniel
Hi @Joao Borges ,
you are probably using some application to be able to create custom fields with a checklist. Do you know, which one it is? Thank you.
