Add automation - copy cloned story's comment into story it's cloned from
Deleted user February 2, 2023
I want to create an automation where
- there is a service ticket and a story that's cloned off of it
- when a comment is added to the story
- I want it copied
- to the original service ticket.
Is that possible?
Vamsi Kandala
February 2, 2023
Hi @[deleted]
You can create the automation rule as follows:
Select the 'Issue commented' as the trigger
Select the 'Branch rule / related issues' component
Select 'Linked issues' for 'Type of related issues'
Select 'clones' for 'Link types'
Select 'New action' under the above branch and click on 'Comment on issue'
In the body of the 'Comment' field, type in {{triggerIssue.comments.last.body}}
Save the changes and test it out.
Hope this helps.
Enclosed the screenshot for your reference.
Vamsi
Deleted user February 3, 2023
@Vamsi Kandala This is awesome, thank you!! Is there a way to add who wrote the comment?
Never mind I figured it out! Thank you again!
