×Right now it only shows a list of 5 boxes that I can check. I have 8 custom fields that are created and added to the issue type this will be populating, but none of those fields show up as an option to select to add on the issue collector. I also don't see an "Add field" button anywhere that would allow me to select from any of the remaining fields. Any help would be greatly appreciated. Thank you!
Are those custom fields present in the create issue screen set on the project?
They are. I've tried combos of making the required, not required, shown, hidden, and everywhere in between and it still doesn't seem to be showing up to select, unfortunately.
Are you able to create a new issue through the Create button from the menu on the top and populate those custom fields normally during issue creation?
Yep. I asked this same question through another channel and the answer I got there is that getting these fields added to the custom issue collector needs to be done via html and javascript as the handler doesn't support adding these additional fields. That might be my next path I pursue.
I confirm I can add custom fields to the issue collector normally, with no need for modifying the html or javascript. What are the types of those custom fields?
There are 8 multi-line text fields, 1 attachment field, and 1 date picker field.
I have configured an issue collector with text multi-line fields without problems:
We also have some buttons there from our custom fields but it does not allow me to choose which ones show up in the list of check-boxes. Is there a setting somewhere that needs to change in order for these to show up in the list of fields available to select?
Just discovered my problem. We had moved this class of work to a new project so all the fields I was looking at were available and able to be created in the new project, but the issue collector I was working on was still under the old project. Glad to have figured it out but annoyed that I spent so much time doing that when the answer was so simple!
Thanks for your help!
Oh, glad you could finally fix it!
Regards
