Add links to an issue - such an option does not exist
e
Hello! I am wondering how am I going to be able to add links to an issue?
I've just created a New project and there is no 'More>Links' option in there.
How do I switch it on?
Thanks beforehand!
Gerald Schneider
February 27, 2014
Make sure your user has the "User" privileges. The Privileges are not additional, if you have the Developer or Admin role you don't have automatically the "lesser" privileges. You need to have all roles (including User) to use all JIRA functions.
Nic Brough -Adaptavist-
February 27, 2014
That's not strictly true, sorry.
February 27, 2014
Check that issue linking is enabled in Admin -> Issue links
Then check the permission scheme for the project to make sure you have permission to create links.
e
thanks!
Gerald Schneider
February 27, 2014
You should post this rather as a comment, not an answer.
