Hi! I want to add a rule that adds a smart checklist template when I set a field condition. What rules should I use?
Hi @lara.fernandez -- Welcome to the Atlassian Community!
Different marketplace apps for checklists implement them in different ways.
Please find the vendor's page in the marketplace, and check the support tab for their documentation link. With that information, they likely will provide examples of using automation with their checklist field.
https://marketplace.atlassian.com/search?query=checklist&product=jira
@lara.fernandez Welcome to the community!
When i set a field condition? this is seomthing you can verify the value of that provided custom field and if the condition matches then the rule move ahead and do the rest of tha action.
However, to run the rule there should be some trigger you need to add likewise, work item created, field vlue upadated etc
If you share that then its very to add the smart checklist.
Thank you
