Add two numeric field in issue by post function in workflow
Zawistowski Grzegorz
How to add two numeric field in post function at workflow.
I must get a result:
numeric1 + numeric2 = numeric3
How could I achieve this in workflow ? Please help.
Nic Brough -Adaptavist-
October 5, 2015
Sumit's answer gives you a script field on an issue.  This is a solution you've been told several times already, but ignored.
It does not happen in the workflow.  If you want to calculate a field in the workflow, then you need a post function (again, something you've been told several times before).
The question that you've refused to answer in other conversations remains what you actually want from this calculation.  Is a scripted field on an issue what you want?  Or a field you can edit after an initial calculation is made?  Or a field somewhere else?
Mayby that's why it dificult to understand JIRA in first time. So how could I sum in workflow by post function two numer filds ? I know I'm ashing very easy Question for You, but how could I do it ?
October 5, 2015
Find or write a post-function to do it. You *still* need to tell us what you want from this field - you haven't answered the question about where you want it to appear.
October 5, 2015
... or how it should behave. Read only or editable.
In the row it could be editable, but total it shouldn't be editable.
October 5, 2015
That is not what you said on the other conversation. You said they should be read only. If you want them editable, then you need a post-function to calculate the value and put it in a field which the user can then change later. We've answered the total thing too - the navigator does not support that, you'll need an add-on.
Sumit Kumar
October 4, 2015
Use calculated number field :
formula should be
<!-- @@Formula: (issue.get("customfield_XXXXX") != null ? issue.get("customfield_XXXXX") : 0) + (issue.get("customfield_XXXYZ") != null ? issue.get("customfield_XXXYZ") : 0) +(issue.get("customfield_XXXYZU") != null ? issue.get("customfield_XXXYZU") : 0) -->
it will work everywhere within JIRA [so no transition restriction will be applied]
XXXXX – ID of calculated number field which shown sum
XXXYZ – First Number field
XXXYZU – Second Number field
And this formulas are in workflows too ? How to learn Jira formulas ? Why You writing a lot != ? issue
Where Coul I put this formula in workflows ?
And You told about Workflows or about Misc fields ?
They shouldyn't be "ID of calculated number field which "
and Could I do calculations by Columns ?
