Adding external identity provider for SSO using Jira (Open ID connect)
girish January 30, 2020
Hello - We have a requirement to integrate our own identity provider with Atlassian Jira so that we can login using our own user management system rather than local users on Jira. Does your platform provide this support?
Ed Letifov _TechTime - New Zealand_
January 30, 2020
Since the question is tagged with jira-cloud, I will assume this is for Cloud.
In Atlassian Cloud integration with identity providers is done via Atlassian Access
As far as I know Open ID is not yet supported with Atlassian Access, only SAML 2.0. The request to add this doesn't seem to get a lot of traction. Consider voting on that? OIDC is supported for Server and Data Center so there may be hope...
For now, if you don't have an option to use SAML instead I guess you will need to look at some kind of "bridge" connector. I may be wrong but I think F5 had some solutions for that...
girish February 1, 2020
Ok thanks for the update.
Ankit
Hi Girish,
Are you using Jira cloud or Jira server?
Jira cloud
