we recently updated our JIRA to version 7.1.8.
Unfortunately one of our scripts doesn´t work any more.
The upcoming error is:
/secure/CreateIssueDetails.jspa [c.a.j.issue.watchers.DefaultWatcherManager] You must specify a user.
This is the code:
import com.atlassian.jira.component.ComponentAccessor import org.apache.log4j.Category def customFieldManager = ComponentAccessor.getCustomFieldManager() def watcherManager = ComponentAccessor.getWatcherManager() def userManager = ComponentAccessor.getUserManager() def watchUsers = {usernames -> usernames.each { def user = userManager.getUserByKey(it.toString()) watcherManager.startWatching(user, issue) } } def users = ["<username>", "<username>", "<username>", "<username>"] def Category log = Category.getInstance("com.onresolve.jira.groovy.PostFunction") log.setLevel(org.apache.log4j.Level.DEBUG) log.debug "--------------- ADD WATCHER/S --------------" watchUsers(users)
I tried some things but I unfortunately can´t find the error.
It seems like the users are defined wrong.
Can anyone see the error?
Best regards,
Michael
Hi Thanos,
thanks for your answer.
I found the error. JIRA compares the lower case usernames.
So I just had to write the usernames in loser case and the csript worked fine.
hi Michael,
I think your script is right, so as you already noticed the problem should be with the user names, try to add a debug message for the user, and check the user for null before the watcherManager.startWatching(user, issue)
regards
