Right now there is a filter which helps in getting the JIRA's assigned to a person. But there is no way to get unassigned or assignee based filtering.
When can I expect this feature to be enabled in the Agility Project?
Hi @san, the best way to see what's unassigned on the board is to group by assignee (you currently need to be a project admin to do this). This also allows you to easily drag and drop issues between swimlanes to update the assignee.
Having a dedicated unassigned filter is something we will look at in the future.
Cheers
