×Hello!
I am trying to set up a Plan using Advanced Roadmaps. Is there a way to show how much is allocated to the sprint vs how much capacity the team has.
For e.g. the team has 5 members and in a sprint of 10 days, total team capacity is 400 hours. I want to see if the items added to the sprint are above or below 400 hours.
If not Advanced Roadmaps, is there any other way to see this in Jira?
Thank you.
/RR
Hello @Rashmi Ratnani
Have you considered using an app? I believe our Team Planner offers exactly what you're looking for - you can easily create a sprint plan, add issues on a timeline, and get a summary of all allocated tasks - both by hours and story points. It will also show the current progress and updates if anything changes in the plan. Here's what your plan may look like. I've also highlighted where the allocation summary is displayed.
Feel free to check it out on the marketplace to see if it fits your needs. There's a 30-day free trial and the app is free forever for up to 10 users. You can also have our team show you the app or help with any configuration if needed. You can book a call with us at any convenient time.
Best regards,
Sebastian
Thanks @Sebastian Brudziński
Unfortunately, I am not sure I will be allowed to add another app for this.
/RR
