We have Jira Data Center 9.12 and have serveral Projects I need to bring toghether:
1. Portfolio Level Project with Epic and Feature
2. Two Program Level Projects with Features and Strories, Subtasks
3. My Onw Project with Feature, Story, Subtask
With the Jira Admin I configured the hirarchie From Epic (Initative) to Feature and so on...
But in the Plan I can not bring the project toghether. For Example. In one Of my Features I assigend in Jira the Parent initative but it is not displayed and selectable in the plan
Hi Julia, and welcome to the Atlassian Community.
Much of the success of Plans/Roadmaps in Jira has to do with the Plan Configuration. Access this with the "Configure" options under the gear icon next to the Plan name (on the left as you view the plan).
There, ensure some basic necessary configuration, such as:
I think that's a pretty exhaustive list. If not, the community will correct me! Hopefully that helps you get your Plan to show what you need.
P.S. I noticed that your post was tagged for Jira "Cloud", but you write that you're using Jira Data Center. It would help others find and respond to your posts if you tagged them with "data-center" instead of "Cloud". People who know DC best might not see your cloud-tagged posts.
