I am using a filter as my source for importing data to Advanced Roadmaps (AR). Most of the Epics I have in my filter have came across to AR, however there are some (visible in the filter), that have not made the journey.
I have checked all the statuses etc but there seems to be no reason these are not transferring.
Any thoughts?
Do all your issue types use the same screens? If not you may be missing a field on the other issue types that are required for Advanced Roadmaps. Specifically off the top of my head make sure that fix version/s is available for the other issue types and that it is also visible if hidden in a field configuration.
Tim
