Advanced Roadmaps auto scheduler ignores scope
pdevannelanglais
I'm trying to use the auto scheduler from Advanced Roadmap on Jira Data Center (v8.22.2). I would like to be able to ask the auto scheduler to schedule only a subset of issues that I selected by checking there respective check boxes in the scope section. However when I press the auto schedule button, all the issues in the plan are getting scheduled.
According to documentation the scheduler should only schedule the selected issues, is there something I'm doing wrong ?
Alexander_Ziegler
January 16, 2024
Is there any update to this topic? I have the same problem. As it is, we are not able to use this feature.
Kind regards
Brett Evans
So after tracking this down this has apparently been classified as working as intended and the UI saying that it should respect selecting of scope has been classified as a bug.
Ticket Work saying this is a Feature and not a bug
https://jira.atlassian.com/browse/JSWSERVER-25768
Ticket Work for fixing the "Bug" of the UI
https://jira.atlassian.com/browse/JSWSERVER-25864
Michael Andolfatto
February 1, 2023
Hi @pdevannelanglais , welcome to the Community!
Would you please share this documentation with me? This behaviour is not true as far as I'm aware, so I would like to verify. Auto-scheduling should affect all issues within your plan (as long as they are estimated or are parent issues)
pdevannelanglais
Hi Michael
This is how I interpret it:
Like Anton likes this
Michael Andolfatto
February 1, 2023
Hi @pdevannelanglais , thanks for the screenshot! You're definitely interpreting this correctly, I was able to verify that the same functionality exists in Jira cloud and my test plan did only schedule the issues I selected.
If more than your selection is getting scheduled, it sounds like it would either be a bug, or the issues are getting their dates from somewhere else.
For the issues being scheduled that should not be- are they parent issues at the Epic-level or higher? Or are they Story-level issues? Are they receiving start/end dates from somewhere else such as a sprint?
pdevannelanglais
Hi @Michael Andolfatto
Sorry for the delay
All issues in my planned are getting scheduled: they are stories and not epics. I checked the check box Use sprint dates when issues don't have start and end dates, but all non selected stories, including the ones that are not part of sprints are getting scheduled.
A couple of things that I can add about my plan:
- there is only one team
- there are some non estimated stories
- there are some stories without any version/release assigned
- lots of dependencies between stories are defined.
pdevannelanglais
@Michael Andolfatto  Any thoughts ?
Kristina_Castor_cardinalhealth_com
August 21, 2024
I am having the same issue with the auto-scheduler.  It is ignoring Scope no matter what I try...
