Hi there, I created an Advanced Roadmap view and used it daily. Suddenly, my permission has been changed to read-only. I asked the IT department, they showed me the log changes, and it seems they didn't change anything.
Please, does anyone know how to fix that? I tried to change all the permissions in the advanced roadmap configuration but got no success. Thank you
Thank you John!
Actually, I discovered that if you have the same group in different permission levels, Jira gets confused, and one of them overrides the other.
Fascinating, but I suppose it makes sense. :) Thanks for posting your follow-up to this, as well.
If you are referring to edit rights within a specific plan... you must go into the Plan itself, to the plan 'Configuration' menu. Select 'Permissions' along the left hand side... and ensure your name is listed within the "Edit" section.
If you are referring to overall create/edit rights, the Advanced Roadmaps section of the Permissions menu has the groups assigned the create/edit rights. Ensure that you belong to one or more of the groups listed there:
