my goal is to get all test executions that derive from a test plan via JQL.
I want to achive this by searching for issue type = test execution where issue propery = particular test plan.
Somehow JQL in the Issue Navigator does not work.
Whenever i use the auto completion the JQL command gets messed up and looks like this
" issuetype = "Test Execution" AND issue.prope"Test Plan" = xxx "
So how should a valid JQL command look like?
Syntax help page is not useful in that case.
BR
Daniel
I dont know why you come up with Zephyr.
I found a solution:
not to try it like this
but this works
Hi @[deleted] ,
Emilys (Zephyr) answer (https://answers.atlassian.com/questions/276873), "It is not possible to mix ZQL and JQL" and "You can only use ZQL in the Zephyr Search Test Executions navigator".
EDIT : I'm mistaken, this issue doesn't have a link with Zephyr. Sorry :/
