Hello, since the update of JIRA, I can not affect the issue any more? Thank you
What do you mean by "affect"? It's a verb that is very vague, especially in terms of Jira. Edit? Create? Comment? Link? Transition? All those actions "affect" an issue.
Could you check your permissions - do you have the project permissions to do whatever you mean by "affect"?
Ok, so check that you both have "assign issue" permission.
Hi!
I have the same problem. I can't affect the issue.
