Hello everyone,
after I installing Self-signed certificate my jira core is unreachable.
I receive following errors.
Connect jira from outer Server with Ip-Address:8443 and DNS-Name
http://mycompany.bla:8443/
error: Bad Request This combination of host and port requires TLS.
Connect jira from Server with DNS-Name
And with
Ip-Address:8443
Error:
If I write extra https://mycompany.bla:8443 or https:// IP-Address:8443
the error is the same with database as above.
My jira uses Windowus active directory.
I took the same values for my jira certificate. as under in picture
Maybe this picture is helpful for you
I don't use appache. I used IP-Tables, but for now I deleted it.
Has anyone an Idea?
hi,
I suggest you to go back to your old configuration for DBCONF, and make the changes on the jira / bin / server.xml, add the this part before <Engine>.... </Engine>:
<Connector port="8443" disableUploadTimeout="true" acceptCount="100" useBodyEncodingForURI="true" protocol="org.apache.coyote.http11.Http11NioProtocol" maxHttpHeaderSize="8192" enableLookups="false" minSpareThreads="25" maxThreads="150" relaxedQueryChars="[]|{}^\`"<>" relaxedPathChars="[]|" keystoreType="JKS" keystorePass="changeit" keystoreFile="C:/Program Files/Atlassian/JIRA/keystore.jks" keyAlias="jira" clientAuth="false" sslEnabledProtocols="TLSv1,TLSv1.1,TLSv1.2,TLSv1.3" secure="true" scheme="https" SSLEnabled="true"/>
just be sure about the aliass and the password
Thank you for response,
But I receive the same Error with the Database.
This part (relaxedQueryChars="[]|{}^\`"<>") doesn't work in linux aber it is no problem. I wrote it for linux.
In my catalina.out file are following errors.
