Hi there,
I'm trying to configure workflow in JIRA 5.x would like the workflow can work like this:
Suppose there are 2 upcoming status for the Create issue, and here is the steps for them:
Create issue-> Status 1->Status2.
And two persons named Person A and Person B, both of them can create issues.
On one hand, after Person A create an issue, the status of this issue would be Status 1, and then Person B make a certain transition, finally the status of the issue would be Status2.
On the other hand, after Person B create an issue, the status would be Status 2, which means the issue would skip Status 1 and go directly to Status 2.
Is it possible to do it? If yes, what do I need to do then?
Thanks in advance,
Not really. You create an issue, it has to go to one status. I suspect this is because it's immensely complicated to have floating targets in workflows, it's far easier to stick to something basic and clear and then build on that.
There is a basic way to work through this - first, make your workflow have transitions from "initial step" to any others you want to land on, and then use a listener to catch the "create" event and automatically push it through that transition. I've used the one in the Jira toolkit to do this a few times, but there are other plugins that make such listeners available - like the one Radu talked about.
I used the auto-transition listener in the "Jira Toolkit"
Hi, you can do this using Script (Groovy) Runner. Jamie made a blog post about something similar here - http://blogs.onresolve.com/?p=235.
Not sure what happened exactly - I thought I voted it up. Now I can't remove the down vote nor can I vote it up. "We're sorry, but an unknown error ocurred. Please try again in a while." Sorry Tracy, but I'll try again later.
Correct. I will vote it back
Thanks Radu.
hmm, and why was this question downvoted ? I can't see anything to complain about it...
totally agre there is no reason for this question to be downgraded.
Many plugins offer an autotransition routine (including ours, JJupin).In this way, when executing postfunction reaching status1, you can jump in status2 conditionally.
