After re indexing issue are showing as zero
srrekanth February 7, 2013
Hi All,
i have exported database and imported in to new and mapped to new testing insatnce. after doing reindexing i am still seeing the issues as zeroa for all projects on administarion home page and when i check throug issue navigator i can view only some issues.
Nic Brough -Adaptavist-
February 7, 2013
Sounds like your indexing has failed.
Could you read the log to find out what went wrong? There must be errors in there.
Hi Nic,
My reindexing was done successfully and please find below:-
2013-02-07 13:29:35,311 http-8085-6 INFO anonymous 809x48x1 1ubhm8t 127.0.0.1 /secure/Setup3.jspa [atlassian.jira.upgrade.UpgradeManagerImpl] Re-indexing is 100% complete. Current index: PortalPage
February 7, 2013
That's a completion message. Look for errors before that.
Hi Nic,
The following are the errors occured during reindexing
2013-02-08 01:09:54,127 IssueIndexer:thread-3 INFO jirasupport 1082x3185x1 plnzcf 10.10.194.231 /secure/admin/jira/IndexReIndex.jspa [action.admin.index.IndexAdminImpl] Re-indexing is 50% complete. Current index: Issue
2013-02-08 01:19:17,178 jira-monitoring-plugin ERROR [jira.plugins.monitor.MetricsCollectorTask] Error running task
java.lang.IllegalArgumentException: Bad sample time: 1360266557. Last update time was 1360266557, at least one second step is required
at org.rrd4j.core.RrdDb.store(RrdDb.java:553)
at org.rrd4j.core.Sample.update(Sample.java:197)
at com.atlassian.jira.plugins.monitor.rrd4j.RrdUpdater.addSample(RrdUpdater.java:76)
at com.atlassian.jira.plugins.monitor.MetricsCollectorTask.doRun(MetricsCollectorTask.java:41)
at com.atlassian.jira.plugins.monitor.MetricsCollectorTask.run(MetricsCollectorTask.java:30)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
2013-02-08 05:37:39,568 IssueIndexer:thread-2 INFO jirasupport 1082x3185x1 plnzcf 10.10.194.231 /secure/admin/jira/IndexReIndex.jspa [action.admin.index.IndexAdminImpl] Re-indexing is 52% complete. Current index: Issue
2013-02-08 05:38:19,146 JiraTaskExectionThread-1 INFO jirasupport 1082x3185x1 plnzcf 10.10.194.231 /secure/admin/jira/IndexReIndex.jspa [action.admin.index.IndexAdminImpl] Re-indexing finished
February 7, 2013
Hmm, I don't recognise that bug at all. Might be worth raising this with Atlassian.
