After the Project migration Test cases are not visible
Ravi Kumar K May 2, 2024
Hi Team,
We have migrated our Jira project from one data center to another data center by using the CMJ add-on and the good thing is the Project migration has been done successfully and we can see all the issues in the project but Test cases are no showing as per the source ,As we can no testcase is getting visible , can some one help me on this how can achieve the test cases in the Target Jira ?
Ravi
Clark Everson
Hi @Ravi Kumar K
CMJ only works with certain third party apps for migration. If it is one of there supported apps you can reach out to their support here: https://appfire.com/contact
However most likely you would either need to manually transfer the data or work with the company that makes the test software app for migration of that data
Best,
Clark
SERVER
