I have upgrade the Core to 7.5.0 and after that upgrade i upgrade the software to 7.5.0 but when i go to the webpage from the server i get the message in the browser This page can't be displayed. Do i need to change something else after the upgrade? The services are running and i have restarted the server also.
Best Regards,
Martijn Bloem
+31610000966 martijn@hype.nl
What are the steps you took before going with this major upgrade?
First make sure if JIRA process is running. If you are using DNS name for accessing JIRA, check if you have modified connector in server.xml with appropriate attributes after upgrade. Upgrade will remove all the customization.
