After upgrade Jira isvery slow and sometimes doesn't respond.
espeake@dmp.com January 16, 2022
Running on Ubuntu. Update from 7.4.3 to 8. mysql upgraded from 5.5 to 5.7 using 8.0 db connector. Upgraded ubuntu from 14.04 to 16.04.
Since the upgrade it took a ton of time to get things to work. Now they are very slow and sometimes unresponsive.
error stating that the collate is wrong and that utf8_bin is not supported.  This is from the database:
mysql> SELECT @@character_set_database, @@collation_database;
| @@character_set_database | @@collation_database |
| utf8mb4 | utf8mb4_bin |
Looking for ideas to see what may be wrong
Thank you,
Eric
espeake@dmp.com February 11, 2022
This was an issue in the setenv.sh file. It was to a minimum. Increased the min-max amounts of memory used.
Eric
SERVER
VERSION
16.04
