Again problems when updating jira 4.1.2. to 4.4.5
Vladislav Mikhaylov June 26, 2014
Hello!
We need to upgrade from version 4.1.2 to version Jira 4.4.5
Began to update instructions (https://confluence.atlassian.com/display/JIRA/Upgrading+JIRA+Manually)
Stopped the service, established a new Jira 4.4.5.
Changed files and server.hml entitiengine.hml
Launched Jira 4.4.5, began restoring a backup of the old jira and display the window:
Oops - an error has occurred
System Error
A system error has occurred.
If this problem persists, please contact your JIRA administrators.
Otherwise, please create a support issue on our support system at http://support.atlassian.comwith the following information:
  1. a description of your problem
  2. cut & paste the error and system information found below
Cause:
java.lang.NullPointerException
Stack Trace: [hide]
	at com.atlassian.crowd.embedded.core.CrowdDirectoryServiceImpl.storeLdapConnectionPoolConfiguration(CrowdDirectoryServiceImpl.java:308)
	at com.atlassian.crowd.embedded.core.CrowdDirectoryServiceImpl.initialiseConnectionPoolSystemProperties(CrowdDirectoryServiceImpl.java:291)
	at com.atlassian.crowd.embedded.core.CrowdDirectoryServiceImpl.getApplication(CrowdDirectoryServiceImpl.java:263)
	at com.atlassian.crowd.embedded.core.CrowdDirectoryServiceImpl.findAllDirectories(CrowdDirectoryServiceImpl.java:81)
	at com.atlassian.jira.user.util.DefaultUserManager.getWritableDirectories(DefaultUserManager.java:261)
	at com.atlassian.jira.user.util.DefaultUserManager.hasPasswordWritableDirectory(DefaultUserManager.java:277)
	at com.atlassian.jira.bc.security.login.LoginServiceImpl.getLoginProperties(LoginServiceImpl.java:92)
	at com.atlassian.jira.bc.security.login.LoginServiceImpl.getLoginProperties(LoginServiceImpl.java:108)
	at com.atlassian.jira.web.action.Dashboard.buildLoginProperties(Dashboard.java:218)
	at com.atlassian.jira.web.action.Dashboard.getCurrentDashboardState(Dashboard.java:205)
	at com.atlassian.jira.web.action.Dashboard.doValidation(Dashboard.java:121)
	at webwork.action.ActionSupport.validate(ActionSupport.java:391)
	at webwork.action.ActionSupport.execute(ActionSupport.java:162)
	at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:76)
	at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39)
	at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31)
	at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16)
	at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35)
	at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:205)
	at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:143)
	at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:152)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
	at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
	at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:44)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
	at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
	at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
	at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
	at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
	at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:103)
	at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:87)
	at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:54)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.obtainContent(SiteMeshFilter.java:129)
	at com.opensymphony.sitemesh.webapp.SiteMeshFilter.doFilter(SiteMeshFilter.java:77)
	at com.atlassian.jira.web.filters.PathExclusionFilter.doFilter(PathExclusionFilter.java:118)
	at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
	at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:211)
	at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
	at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:150)
	at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
	at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
	at com.atlassian.util.profiling.filters.ProfilingFilter.doFilter(ProfilingFilter.java:99)
	at com.atlassian.jira.web.filters.JIRAProfilingFilter.doFilter(JIRAProfilingFilter.java:19)
	at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
	at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:350)
	at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:81)
	at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
	at com.sysbliss.jira.plugins.workflow.servlet.JWDSendRedirectFilter.doFilter(JWDSendRedirectFilter.java:25)
	at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
	at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
	at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:49)
	at com.atlassian.jira.web.monitor.ActiveRequestsFilter$PassToChainFilterFunc.doFilter(ActiveRequestsFilter.java:346)
	at com.atlassian.jira.web.monitor.ActiveRequestsFilter$DebugLogFilterFunc.doFilter(ActiveRequestsFilter.java:463)
	at com.atlassian.jira.web.monitor.ActiveRequestsFilter.doFilter(ActiveRequestsFilter.java:173)
	at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:75)
	at com.atlassian.multitenant.servlet.MultiTenantServletFilter.doFilter(MultiTenantServletFilter.java:91)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:554)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
	at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:859)
	at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
	at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
	at java.lang.Thread.run(Thread.java:662)
Referer URL: https://10.33.101.117:8443/secure/admin/EditApplicationProperties!default.jspa
Build Information:
Uptime : N/A
Version : 4.4.5
Build Number : 665
Build Date : Wed Feb 15 00:00:00 MSK 2012
Build Revision : 422aeadac7e4462fb4ae63fce804ff78c4258dd6
Atlassian Partner : null
Installation Type : Standalone
Server ID : Contact your Administrator to discover this property value.
Last Upgrade : 07/авг/10 11:05 AM
Server Information:
Application Server: Apache Tomcat/6.0.32
Servlet Version: 2.5
File Paths:
Contact your System Administrator to discover file path information.
Memory Information:
Total Memory: 716 MB
Free Memory: 71 MB
Used Memory: 645 MB
Total PermGen Memory: 256 MB
Free PermGen Memory: 146 MB
Used PermGen Memory: 109 MB
System Information:
System Date : пятница, 27 июн 2014
System Time : 12:18:56 +0400
Current Working Directory : Contact your System Administrator to discover this property value.
Java Version : 1.6.0_26
Java Vendor : Sun Microsystems Inc.
JVM Version : 1.0
JVM Vendor : Sun Microsystems Inc.
JVM Implementation Version : 20.1-b02
Java Runtime : Java(TM) SE Runtime Environment
Java VM : Java HotSpot(TM) Server VM
User Name : vm3640
User Timezone : Europe/Moscow
User Locale : русский (Россия)
System Encoding : Cp1251
Operating System : Windows 2003 5.2
OS Architecture : x86
Application Server Container :
Database type : hsql
Database JNDI address : hsql jdbc:hsqldb:D:\Atlassian\Application Data\JIRA/database/jiradb
Database URL : Hidden
Database version : 1.8.0
Database driver : HSQL Database Engine Driver 1.8.0
External user management : OFF
Crowd integration : ON
JVM Input Arguments : Contact your System Administrator to discover this property value.
Language Info:
Installed languages: английский (UK)
английский (Соединенные Штаты)
венгерский (Венгрия)
датский (Дания)
испанский (Испания)
итальянский (Италия)
каталанский (Испания)
китайский (Китай)
китайский (Тайвань)
немецкий (Германия)
немецкий (Швейцария)
нидерландский (Бельгия)
норвежский (Норвегия)
польский (Польша)
португальский (Бразилия)
русский (Россия)
словацкий (Словакия)
турецкий (Турция)
французкий (Франция)
чешский (Чехия)
японский (Япония)
Default language: русский (Россия) - System Default
Request Information:
- Request URL: https://10.33.101.117:8443/500page.jsp<br< a="">>- Scheme: https
- Server: 10.33.101.117
- Port: 8443
- URI: /500page.jsp
- Context Path:
- - Servlet Path: /500page.jsp
- - Path Info: null
- - Query String:
Request Attributes
- javax.servlet.forward.request_uri : /secure/Dashboard.jspa
- javax.servlet.forward.context_path :
- javax.servlet.forward.servlet_path : /secure/Dashboard.jspa
- javax.servlet.forward.path_info : /500page.jsp
- os_securityfilter_already_filtered : true
- com.atlassian.jira.web.filte...
Request Logging
0 log statements generated by this request:
Listeners
- Issue Assignment Listener (com.atlassian.jira.event.listeners.history.IssueAssignHistoryListener)
- Issue Cache Listener (com.atlassian.jira.event.listeners.cache.IssueCacheListener)
- Issue Index Listener (com.atlassian.jira.event.listeners.search.IssueIndexListener)
- Listener for VertygoSLA (com.valiantys.jira.plugins.vertygo.sla.listener.AutoRetrieveAgreementListener)
- Mail Listener (com.atlassian.jira.event.listene...
Plugins
- ActiveObjects Plugin - OSGi Bundle 0.17.13 - Plugin by Atlassian
- Enabled
- Admin Menu Sections 1.0 - Plugin by Atlassian
- Enabled
- Apache HttpClient OSGi bundle 4.0 - Plugin by Apache Software Foundation
- Enabled
- Apache HttpCore OSGi bundle 4.0 - Plugin by Apache Software Foundation
- Enabled
- Applinks Product Plugin 3.5.6 - Plugin by Atlassian
- Enabled
- build: 10
- Atlassian Embedded Crowd - Administration Plugin 1.3.4 - Plugin by Atlassian
- Enabled
- Atlass...
http://www.aQute.biz<br< a="">> - Enabled
- Content Link Resolvers Plugin 1.0 - Plugin by Atlassian
- Enabled
- Crowd REST API 1.0 - Plugin by Atlassian Software Systems
- Enabled
- Enabled
- Crowd System Password Encoders 1.0 - Plugin by Atlassian Software Systems
- Enabled
- Custom Field Types & Searchers 1.0 - Plugin by Atlassian
- Enabled
- Embedded Gadgets Plugin 3.1.21 - Plugin by Atlassian
- Enabled
- FishEye Plugin ...
please help.
Our database oracle
Made as described in the instructions.
restarted Jira
And there was this:
The data before the upgrade has been exported to D:\Atlassian\Application Data\JIRA\export\jira_autoexport_20140627_155704.zip2014-06-27 15:57:12error
Exception thrown during upgrade: null
at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build602.migrateGroups(UpgradeTask_Build602.java:629)
at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build602.migrateGroups(UpgradeTask_Build602.java:588)
at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build602.doUpgrade(UpgradeTask_Build602.java:111)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeTaskSuccess(UpgradeManagerImpl.java:609)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.runUpgradeTasks(UpgradeManagerImpl.java:496)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgrade(UpgradeManagerImpl.java:426)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeIfNeeded(UpgradeManagerImpl.java:370)
at com.atlassian.jira.upgrade.UpgradeManagerImpl.doUpgradeIfNeededAndAllowed(UpgradeManagerImpl.java:309)
at com.atlassian.jira.upgrade.UpgradeLauncher.checkIfUpgradeNeeded(UpgradeLauncher.java:100)
at com.atlassian.jira.upgrade.UpgradeLauncher.start(UpgradeLauncher.java:49)
at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:103)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:250)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:149)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:94)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:24)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:61)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:56)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:68)
at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:63)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121)
at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130)
at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:96)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4205)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4704)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
at org.apache.catalina.core.StandardService.start(StandardService.java:525)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Pedro Cora
June 26, 2014
This is a known issue that is covered on a Knowledge Base article: https://confluence.atlassian.com/display/JIRAKB/Cannot+Login+to+JIRA+after+Upgrade+due+to+Null+Pointer+Exception
Take a look and see if the problem goes away. :)
