Is there a way to generate a view that shows all of the project's component roadmaps on one report? The gist of the report is to show the project component roadmaps in a matrix where the component is on the y-axis and each version/release date on the x-axis. The version progress bar would be shown where the two axis meet to get a quick overview how things are going for the project as a whole. For example
Component V1 V2 component a [xx---] [x-----] component b [xxxx-] [------]
Is this possible with JIRA v4.4.3#663-r165197?
-Wade
That is not something supported in Jira OOTB. But, if you are using Green Hopper, you could achieve this in a different way.
1. Have per component Contexts created and you can see the Hour Burndown Charts which can predict per component end dates for a release
2. Use a Project level context to check the overall progress of the Project.
You won't get this in a single view, but of course it shows the relevant data as per the way the project is proceeding based on the real burn down.
