Agile Classic Project Progress Gadget Not Displaying "To Do" or "Done"
Jared Giles April 23, 2015
Right now my gadget only tracks "In Progress" even though I have two issues that are marked as "To Do". How can I make sure my gadget tracks issues properly? In the screenshot below, the issue INT-1 has a status of "To Do" but the gadget only shows 2 "In Progress" issues.
Jaime S
April 23, 2015
Hi, Jared.
I honestly don't know who that gadget works, but it seems to me that it's using status categories, not the status themselves. That is, it seems, for example, that it is aggregating all status of 'In Progress' category in the yellow color (which is indeed its color).
You should check that by add issues to statuses of those categories and seeing if they affect the category.
I hope it was helpful.
Jaime Kirch da Silveira
Atlassian Cloud Support
Hi Jaime, Thanks for your reply! I'm a bit new to JIRA so I have a question about your answer. My "status categories" are 'To Do', 'In Progress', and 'Done', right? And the statuses are the same, but are determined by where the issue is in the workflow? If that's right then all of my issues are in Sprint 1, marked with a status of To Do. I've started and stopped progress on the issues but nothing has changed. The status seems to be right, but it's not reflected in the gadget. Thanks for your help.
Jaime S
April 24, 2015
Hi, Jared. JIRA has 2 concepts: statuses and statuses categories. The status categories are only 3: To Do, In Progress and Done. They cannot be changed, removed or new added. The status are customizable and you can add and remove. Each status has a category, one of the three. The status in each workflow are mapped to workflow steps and each step is a position in the workflow. In other words, the status indirectly tells which step you are in the workflow. That is, is pretty similar to what you said. If you status to status categories are correctly mapped, this should work and the gadget should change. Since it does not, I'm not sure what is causing. Maybe is because this is Classic Agile gadget and classic agile is no longer supported in Cloud. If you need some further investigation, you can open a support request at support.atlassian.com in the Cloud project. Kind regards, Jaime Kirch da Silveira Atlassian Cloud Support
Jared Giles April 24, 2015
Thanks Jaime. I checked the statuses and their status categories and everything matched up correctly, so it may be an issue with classic agile not being supported. Thanks for your help!
Jaime S
April 27, 2015
No problem, Jared.
