Did the advanced roadmap get merged to Agile projects? struggling to configure advanced roadmap on the agile projects
I believe "Advanced Roadmaps" are now under "Plans" for projects in Jira. You probably figured that out.
If you have some specific questions about configuring them, providing some details would allow the community to be more helpful to you.
Plans are difference between Next-Gen and Classic projects, so knowing which type of project(s) you're using with Plans will be helpful too. Some documentation links:
