×Hello
I need some help , I need to create a custom workflow for Agile project and being fairly new I dont want to screw it up
the Agile project workflow needs to look like this if anyone can give me a little guidance
Feature --> EPIC --> User Story --> Task
EPIC - by selecting a feature user should be able to see all the EPICs linked to it
User Story - by selecting EPIC the user should be able to see all user stories.
the project is created already using the defaults pretty much
thanks in advance
Hi @Troy E
Please note that by defining this "hierarchy":
The only way to see this hierarchy vertically would be via third party-app Structure.
This vertical hierarchy won't be possible however in Advanced Roadmaps as AR only allows you to create an additional level above the Epic issue type (so Feature would be 'above' Epic), but it won't allow you to set a Task below User Story (as they are both standard issue types).
