Hi all,
In agility projects, I can add new custom fields to issue types.
Is it also possible to add existing fields that I already use in projects with non-Agility templates? E.g., I would like to use some custom fields (provided by Tempo plugin) for Agility projects as well.
Thank you
Yes the fields that are created by the plugin can be used in the projects. You will just have to go into the project settings finds the screens that you would like to add the fields to and then start adding the fields that you would like to onto the screens.
