HI - I have an Advanced Plan with 27 Jira Projects, and about 4,000 issues (so below the 5,000 limit)
On the Advanced Plan, all projects show, including 'Tech Adoption'.
However when embedded on Confluence this Tech Adoption project does not show.
Also If I try and open in a new tab for a larger view, the Tech Adoption project also does not appear there.
This is really strange and I can't figure out why ?
Any explanation or advice would be greatly appreciated.
guidance would be much appreciated.
To add, this seems to happen to the last project (alphabetically) that is on the Advanced Plan. The missing project here 'Tech Adoption' was not appearing. I added a project 'Web Ops' and now Tech Adoption appears as the last project, but Web Ops does not appear on the default view. It is however available under the Projects filter. It seems to be an issue/bug with the last project
