All test cases is not in a test execution or a test plan
Herbert Kevin August 12, 2020
do you know how to select all test cases of a project,
which are not in a test execution
or which are not in a test plan.
Do you have any JQL?
Thanks for your help.
Best regards.
Herbert
Jarosław Solecki [Deviniti]
@Herbert Kevin Hi,
which addon do you use?
With Requirements and Test Management for Jira we suggest only Test Cases which are not added to your Test Plan (that one currently edited) yet.
You can also try JQL described in that ticket:
https://community.atlassian.com/t5/Jira-questions/how-do-i-search-for-issues-without-Issue-Links/qaq-p/300372
So you can base you JQL on Link Type or on Issue Key.
