Allow changes via structure does not work for grouped assignees and sprints
amir amir
January 27, 2021
Hi
I have listed my issues in backlog and also have set their assignee's. Then made my first sprint in the backlog.
I made a structure with automaion using the "Bottom up automaion for backlog grooming" mentioned in structure official tutorial; inserting issues , group by assignees and group by sprint name.
Some of issues are listed in "no value" sprint below their corresponding assignees. Then in the structure I try to move an issue from no value sprint to sprint1 under the corresponding assignee but I saw the "cannot handle this operation" error dialog. Note that  I have enabled the "allow changes via structure" for both group generators.
I am using Jira software version 8.13.2 and structure version 8.4.0
Mario O.G
February 4, 2021
Hi Amir!
If I understand the scenario correctly, we might be able to achieve your goal by doing the following:
1. Instead of grouping by Sprint name, choose to group by "Sprint..."
Automation > + > Group > Sprint...
2. After that, try moving one of the 'Backlog' items to an Active sprint group. Observe if it works.
All the Best,
Mario O.G
[ALM Works]
