Am facing issue while simplified workflow
Jay Narayanan March 23, 2020
hello,
Kindly verify attached screenshot. How to resolve this issue?Screen Shot 2020-03-23 at 10.46.20 AM.png
Hazwan Ariffin
March 23, 2020
As per this comment:
  1. Copy the stubborn workflow and workflow scheme
  2. Assign the project to use the copy of the scheme
  3. Delete the original "Simplified" workflow scheme and workflow
  4. Now you should be able to do the "Simplify" step again
  5. Delete the copy workflow scheme and workflow
If you cannot find the scheme and workflow look in the "inactive" section on those pages.
You must delete the scheme first, then the workflow. The other way around is not possible
@Hazwan Ariffin is it possible to make a call?  +965 - 99023559
@Hazwan Ariffin  how to bring this Add status button under specific boardScreen Shot 2020-03-23 at 9.39.20 PM.png
Hazwan Ariffin
March 23, 2020
The "add status" button will only appear if your workflow for the board has been "simplified". Using the screenshot provided as an example, you can see that it says Using Simplified Workflow. If it is not a simplified workflow, the add status button would not be enabled as the workflow is a complex workflow where you can't just simply add a status. In that case, the status within the workflow(s) can only be modified by your administrators. To have the add status button, you would need to simplified the workflow.
See here - Using Simplified Workflow to give you more context on what is Simplified Workflow. Hope that helps!
Jay Narayanan March 27, 2020
Is there any support by calling?
Nic Brough -Adaptavist-
April 13, 2020
Only if you have premium support.
I'd recommend doing what the system suggests - go to Admin -> Issues -> Workflows, find the existing workflow of that name and edit it, changing the name.
Jay Narayanan May 9, 2020
What is the step to make premium support
