Ambiguous method overloading for method ApplicationUsers#from
THOMAS SEBASTIAN
Recently we upgraded to JIRA 6.3.15 and ScriptRunner v3 and one of the our Scripted Fields does not work anymor.  The log file records the following error:
groovy.lang.GroovyRuntimeException: Ambiguous method overloading for method com.atlassian.jira.user.ApplicationUsers#from.
Cannot resolve which method to invoke for [null] due to overlapping prototypes between:
[interface com.atlassian.crowd.embedded.api.User]
[interface java.util.Collection]
It was working just fine previously in JIRA 5.  I'm aware of a change in ApplicationUser interface in JIRA 6 but just wondering if the problem lies with my script or the fact that the use of this interface has been changed since the upgrade?
My script is just a simple script that collects user from customfields:
Collection<ApplicationUser> appUserCollection = []
appUserCollection.add(ApplicationUsers.from(issue.getCustomFieldValue(CustomFieldObject)))
THOMAS SEBASTIAN
Hi Jamie, Thanks for the pointer. We handled the null value by adding '?' operator when getting the custom field value. However what we found is that your suggestion still returns the same error. We tried different permutations such as below (enforce it in one level before):
appUserCollection.add(ApplicationUsers.from(issue.getCustomFieldValue(CustomFieldObject)) as ApplicationUser)
But still received the same error. If I enforce it at the lowest level like this:
appUserCollection.add(ApplicationUsers.from(issue.getCustomFieldValue(CustomFieldObject) as ApplicationUser))
We will get
'No signature of method: static com.atlassian.jira.user.ApplicationUsers.from() is applicable for argument types: (null) values: [null]'.
What we found to be working is to enforce it as User when the ApplicationUsers is calling the 'from' method:
appUserCollection.add(ApplicationUsers.from(issue.getCustomFieldValue(CustomFieldObject) as User))
as this will feed User type to ApplicationUsers and return a single User. Hope this can help others.
JamieA
April 17, 2015
You're right, in my example I had the "as ApplicationUser" in the wrong place, it should have been inside the parens. Better though just to check it for null then do something else.
JamieA
April 9, 2015
It's going to fail when issue.getCustomFieldValue(CustomFieldObject) is null, as there are two methods for  com.atlassian.jira.user.ApplicationUsers#from. In groovy, method selection happens at runtime.
So you can handle the null value yourself, or force one or other method to be selected by using
appUserCollection.add(ApplicationUsers.from(issue.getCustomFieldValue(CustomFieldObject))) as ApplicationUser
(or the other choice).
